H2B alternator bracket
Old Jul 1, 2007 | 08:58 PM
Winlight's Avatar
Default H2B alternator bracket
can i use the stock alternator bracket for the h22a?i know most people use the explicitspeed one.
Old Jul 2, 2007 | 09:17 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: H2B alternator bracket (Winlight)
sure can, if the crank pulley will remain in the stock location that is.
Old Jul 2, 2007 | 03:17 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight &raquo;</TD></TR><TR><TD CLASS="quote">can i use the stock alternator bracket for the h22a?i know most people use the explicitspeed one.</TD></TR></TABLE>
only if you want to cut the **** out of your frame rail. Spend the$75 on the bracket and run a lighter/smaller SOHC alternator.
Old Jul 2, 2007 | 06:10 PM
RotiEatter's Avatar
Ditto
Default Re: H2B alternator bracket (2fast4u831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote">sure can, if the crank pulley will remain in the stock location that is.</TD></TR></TABLE>
heh heh heh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
only if you want to cut the **** out of your frame rail. Spend the$75 on the bracket and run a lighter/smaller SOHC alternator.</TD></TR></TABLE>
fa sho. It's MAD JDM to cut your frame rail like whoa.
Old Jul 2, 2007 | 07:43 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight &raquo;</TD></TR><TR><TD CLASS="quote">can i use the stock alternator bracket for the h22a?i know most people use the explicitspeed one.</TD></TR></TABLE> the braket ui got from explicitspeed was junk. i lost 2 belt $13 each. i had to grind the **** out of it so it would stop kicking the belt off
Old Jul 3, 2007 | 06:29 AM
Bense's Avatar
yeah those ********* didn't bother to tell us that you have to use an EF bracket. it doesn't work with the 92-00 alts for ****.
Old Jul 3, 2007 | 07:40 AM
ESP.net's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote"> the braket ui got from explicitspeed was junk. i lost 2 belt $13 each. i had to grind the **** out of it so it would stop kicking the belt off </TD></TR></TABLE>
Give us a call and I will get you a new one if there is a defect. Every alternator kit is checked quite a few times in the process. They are difficult to make and like every product we do is Hand Made so one or two out of a hundred might be off very slightly. I will take that percentage any day. Most of the time the alteration to get them to line perfectly is lil and can be as simple as using a ruler and a rubber mallet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">yeah those ********* didn't bother to tell us that you have to use an EF bracket. it doesn't work with the 92-00 alts for ****. </TD></TR></TABLE>
I learn from you guys and sometimes with you guys in trial and error. 88-91 D series alternators are very plentiful. I have since recommended only using 88-91 D series atlernators 3 ribbed belt and pulley. 92+ use a 4 ribbed pulley and belt that Bense brought to my attention...I have personally used on my H22 Crx our D series upper kit with 88-91 D alt. with no issues for over 2 years now...
Old Jul 3, 2007 | 11:10 AM
turbociviccoupe's Avatar
Default Re: (ESP.net)
i got a friend to make it and its way cheaper than the explicitspeed one to make
ca-rs
Jun 16, 2010 12:50 PM
CRAZY-EG9
Apr 4, 2008 02:36 PM
almerricking
Nov 20, 2007 05:10 AM
GoLowDrew
Welding / Fabrication
10
Oct 4, 2007 03:35 PM
