I started my engine with no oil.
I just put a B20 in my integra from HMO and i cranked it 3 times before it started. It ran for like 5 or 6 seconds at idle before i realized i forgot the oil...
Its spitting small clouds of white smoke intermittently right now.. Is this as bad as im thinking?
Re: I started my engine with no oil. (richard7968)
i would say your alright if you didnt tear into the engine and it has a little resudial oil in there. there wasnt any load, you didnt run it that long, fill it with oil and pray that god is on your side today
Re: I started my engine with no oil. (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel »</TD></TR><TR><TD CLASS="quote">i would say your alright if you didnt tear into the engine and it has a little resudial oil in there. there wasnt any load, you didnt run it that long, fill it with oil and pray that god is on your side today</TD></TR></TABLE>I think its fine cause i got it from HMO and they squirt oil in the cylinders for compression tests. So there was residual oil in there. Also, the engine sat for almost a year so any oil that would have been in there wouldnt have circulated much in those 5 seconds...
The engine started and ran just fine... thanx for the replies....
GoLowDrew
07-31-2006 07:10 AM
