Ca Ref Question
Old Jul 2, 2007 | 07:18 PM
99hatchboy's Avatar
Default Ca Ref Question
i was wondering if i have a 91 Da with a b18a1 and wana swap it with a b16 or a b18c1 i know ill have to switch obd's and its 1.8 and 1.6 will i have to get my car Reffed to pass smog since its not the same motor and i was also wondering if its the same thing with d series motors. thanks in advance
Old Jul 2, 2007 | 11:31 PM
Winlight's Avatar
Default Re: Ca Ref Question (99hatchboy)
if the moter wasnt offerd in the car in california then you need to get it reffed
Old Jul 3, 2007 | 04:31 PM
99hatchboy's Avatar
Default Re: Ca Ref Question (Winlight)
so if i was to drop in a b17 i wouldnt have to get it reffed?
Old Jul 5, 2007 | 11:28 AM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">so if i was to drop in a b17 i wouldnt have to get it reffed?</TD></TR></TABLE>
If it's not the b18a1 engine you're replacing it with then YES you will have to bar it... unless you find someone to smog it for you for a price.
Old Jul 6, 2007 | 12:10 AM
broketuner-Sol_Si's Avatar
The main things that matter are:
motor is the year o the car or newer(matching OBD would be best)
-ALL smog equipment must be installed correctly and working(can use an aftermarket cat, but oem seems to burn cleaner)
-All wiring is OEM spec or better(IE: soldered and heatshrunk)
-US spec ECU for that motor
some additional things I'd reccomend:
-seafoam (just follow the directions)
-FULL tuneup(cap, rotor, plugs, wires)
-borrow an OEM cat
-fresh oil change
-run the car really hard for at least 30 min right before going for the test
-say a prayer
slo_ej8
Oct 28, 2007 05:19 PM
kDA
Aug 9, 2006 10:16 AM
SRd240sx
Aug 30, 2005 11:46 PM
onesikviet
10
Jan 5, 2004 08:35 PM
The Alchemist...
Oct 15, 2003 10:50 AM
