1990 CRX SI W/ obd1 gsr swap, fuel injectors are not spraying
Hey everyone. I just swaped over a freshly built obd1 gsr. I am using a ry-wire converted engine harness, and a locash racing v-tec subharness with ecu and distributor adapter.
Here is the deal. I finish up the swap and I have no spark. Turns out locash wired the dizzy adapter wrong. I re-wire according to a h-t diagram someone posted and I have spark! It still wont run. I have fuel pressure at the rail, so my fuel pump is coming on, but the injectors are not fireing. I have no fuel in the cylinders when I pull the plugs out. I ohm each injector and they all are aroud 12 ohms. Where should I go from here? I do not have a noid light set, I am trying to see if I am getting a pulse at the injector clips, or if it is the injectors themself. Any ideas? I am wondering since locash wired the dizzy adapter wrong maybe he wired the ecu adapter wrong?
-Chris
-Chris
Re: 1990 CRX SI W/ obd1 gsr swap, fuel injectors are not spraying (mahatma)
Yep, resistor box gone and an obd1 plug was installed in the harness, it links the injectors to the power wire.
-chris
-chris
Re: 1990 CRX SI W/ obd1 gsr swap, fuel injectors are not spraying (white90rexsi)
Tomorrow I am going to make sure the jumper harness is correct. Does anyone have a pin out picture of the obd0-obd1 harness? I found a pin out but I need a pic as my jumper is not labeled.
-Chris
Modified by white90rexsi at 10:53 AM 6/26/2007
Modified by white90rexsi at 10:54 AM 6/26/2007
-Chris
md88hfcrx
06-06-2007 07:12 PM
