Before I drill, how does the location of engine mount look??
I want to get some opinions before I drill the 2 1/2" holes for the passenger side mount. Hasport mounts, K20a2 swap, 95 Civic if you are curious.
Installed the 2 bolts from the bottom to hold the mount in place and make sure the mount was centered for drill markings:
The mount had a slight bit of movement from side to side even with the bolts in the bottom. So, I took the center placement best as possible:
Centers marked:
Removed. Can anyone compare your pics with what I have here:
**Don't mind the double marking on the right. I felt the marking was a little off to the right and made the 2nd marking to bring it back to the left**
Looks like the hole on the left is going to be double drilled. Do you guys remember that happening when you drilled
Car is going off for paint in the morning. I want to drill the mount before it gets painted
Thanks for any feedback
Centers marked:
Loveless
10-14-2003 09:52 AM
