Z6 IM on Y7?
Re: Z6 IM on Y7? (sky9)
all d-series manifolds (intake and exhaust) will bolt up.
you'll have to figure out hoses and wiring with certain IM's.
with this one you have to use your y7 TB.
Location: the asshole of america..., upstate new york, USA
i would suggest an automatic y8 manifold depending on your setup...that way you can use the stock throttlebody and 3-wire iacv, plus have an ecu that can control the iacv.
unless of course, you only have a y7 motor in another car...or there is a way to control the 2-wire iacv with the y7 ecu that i dont know about...
Re: Z6 IM on Y7? (fastcrxsi90)
actually the manual y8 manifold is more versatile. it has the 2pin iacv on the back just in case you decide to do a mini-me or something like that later. just reuse the y7 TB with it and make sure you take a close look at the TB gasket before you put it together.
i think you have to use the y8 gasket... but i can't remember so just look. the wrong one leaves a gap on the lower side of the TB
SOHC_civic_si
05-04-2008 08:50 PM
honda616
11
05-20-2007 01:51 PM
