b16a SiR and b16A2 EM1 question?? not the normal
I have a b16a obd0 from a SiR, and I have a b16A2 in my EM1, I want to have a built engine so I can boost it but I can't have the down time associated with the build. So I was thinking about just building the obd0 bottom end and then swapping it with the obd2 bottom end, and using the head from the EM1. Is this a bolt on swap or will it need modifying and if so what needs to be done? Basiclly will a obd0 bottom end fit on a obd2 head? PIcs because people like pics!
Moderator
Re: b16a SiR and b16A2 EM1 question?? not the normal (elitesi8)
there are slight differences in the blocks...but the most part you'll be fine....make sure to use obd2 oil pump on the non obd engine and the water tube and oil cooler from em1.
chad
chad
Re: b16a SiR and b16A2 EM1 question?? not the normal (chad)
I hear you have to use the crank sensor from the A2? I guess the 0bd0 doesn't have one? Where is that?
Re: b16a SiR and b16A2 EM1 question?? not the normal (rizzoTK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizzoTK »</TD></TR><TR><TD CLASS="quote">on the oil pump.</TD></TR></TABLE>
AAHHHH, that makes sense!
