b20 or gsr?
Old Feb 26, 2008 | 09:43 PM
krazeenoy's Avatar
Default b20 or gsr?
does anyone know which crank is better? b20 or gsr?
Old Mar 23, 2008 | 05:39 PM
daver's Avatar
Default Re: b20 or gsr? (krazeenoy)
which ever costs more is better
Old Mar 24, 2008 | 03:11 PM
LastGenEK's Avatar
wow
Old Mar 24, 2008 | 03:12 PM
LastGenEK's Avatar
Default Re: b20 or gsr? (LastGenEK)
you should give more info, Those cranks are way different in stroke, cant quite compare them
Old Mar 30, 2008 | 02:51 PM
dc4stunner's Avatar
What block are you using, i assume the b20, right? the gsr would require special pistons to work. i have heard of the gsr cranks handling over 700 hp, but never heard on the b20. i think the gsr crank is cast, like the b20 crank is, but not sure. from what i have seen, the gsr will work in the b20 block, as far as bearing journal sizes, so its your call.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daver &raquo;</TD></TR><TR><TD CLASS="quote">which ever costs more is better </TD></TR></TABLE> that is not necessarily true, if you research the cranks, you may see alot in common, but everyone may think one is better, so they would pay more for that.
Old Mar 30, 2008 | 04:38 PM
daver's Avatar
Default Re: b20 or gsr? (dc4stunner)
it was kind of 'stupid question stupid answer' joke.
jeffnerette
Dec 14, 2009 08:01 PM
TurbodTegSfaria
Oct 5, 2009 03:36 PM
Part1
Jan 29, 2005 09:24 AM
