What is my problem? Y8 IM on A6
im hench irl
Re: (AGENT 99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 »</TD></TR><TR><TD CLASS="quote">vacuum leak.</TD></TR></TABLE>
And lease check to make sure your TB isnt stuck open for some reason. Seen his happen plenty of times.
You think? It will rev all the way to red line. TB is closed.
It also smokes too.
I am using y8 tb, should I try the a6 tb?
Im sorry for posting this in gdd, ef gets no traffic and 92-00 is full of tards, and I need to be somewhere soon
It also smokes too.
im hench irl
Re: (EJAYATE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJAYATE »</TD></TR><TR><TD CLASS="quote">You think? It will rev all the way to red line. TB is closed.
It also smokes too.
Im sorry for posting this in gdd, ef gets no traffic and 92-00 is full of tards, and I need to be somewhere soon </TD></TR></TABLE>
Did you torque down your IM properly? If its revving all the way to redline u have a vaccum leak somewhere.
It also smokes too.
Re: (esco562)
vacuums are easy enough to check, just spray carb cleaner all over see whats up.
id check ur iacv also, the little valve on the back of the im that has two coolant hoses going into it.
and i beleive white smoke is coolant, but i always get em mixed up so id verify this
Thanks for the quick help, I got it figured out. esco you da man. I retorqued, it got a lil better retorque lil better.............. 10 torques latter its good. still idles a lil rough but I can figure that out.
im hench irl
Re: (EJAYATE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJAYATE »</TD></TR><TR><TD CLASS="quote">Thanks for the quick help, I got it figured out. esco you da man. I retorqued, it got a lil better retorque lil better.............. 10 torques latter its good. still idles a lil rough but I can figure that out.</TD></TR></TABLE>
Dont just torque them randomly.
Torque it to spec with a torque wrench to 17ft-lbs for each bolt in this order.
.....4...2.....3....5....
..6..........1...........7
jdejesus3
10-01-2007 05:34 PM
92integra_gs
05-31-2005 02:53 PM
