H22 idling issues
Old Mar 17, 2008 | 08:03 AM
bassysingh's Avatar
Default H22 idling issues
For some reason i'm having idling issues with my swap. H22 into EK. Obd-I motor. With gas runs like it should but at idle it "purges". Any suggestions? I was thinking maybe a vacuum problem. If so do i need to have all the different check valves and what not?
Old Mar 17, 2008 | 04:44 PM
2point2's Avatar
Default Re: H22 idling issues (bassysingh)
What do you mean by "purge".. can you describe the issue more clearly?
Here's a common issue with all honda engines:
https://honda-tech.com/zerothread?id=1564019
look at step 8.
this valve works itself loose (unscrews itself) over time. A lot of the time you just need to screw the valve back in, put everything back together and you're good to go. The thread is for a gsr motor but this valve is similar amoung all honda engines that use them.
There are a lot of other threads regarding the "FITV" if you want to search.
Old Mar 17, 2008 | 05:54 PM
PwRLiMeH22's Avatar
Mine did that and it was IACV. Idle surge, eh?
Old Mar 17, 2008 | 07:52 PM
bassysingh's Avatar
i guess it can be described as a surge. revs high then low, high then low, high then low. Kinda like if you went on and off the gas.
PwRLiMeH22 - how'd you fix it? you just changed the IACV?
Old Mar 30, 2008 | 05:43 AM
bassysingh's Avatar
Anybody else?
Old Mar 30, 2008 | 07:54 AM
nitch_bigger's Avatar
yeah thats what id start with. sounds like the problem. my friends car is doin that right now i told him to change his.
Old Mar 30, 2008 | 09:03 AM
e46civic's Avatar
Default Re: (nitch_bigger)
Is your EGR hooked up, if not you need to make a block off plate.
Old Mar 30, 2008 | 05:19 PM
bassysingh's Avatar
no, egr is not hooked up. can anybody gimmea "how to" on a block off plate. for some reason i sound like a damn noob with this crap. also keep in mind that it's only doing this when it's cold. once it heats up it's fine. could it be the coolant temp sensor?
Old Apr 1, 2008 | 05:51 PM
bassysingh's Avatar
ok, maybe not?
Old Apr 1, 2008 | 06:53 PM
mtsepulveda85's Avatar
Default Re: (bassysingh)
http://cgi.ebay.com/ebaymotors...ZWDVW
block off plate hope it helps
EuroR_EK
Feb 15, 2012 07:57 AM
projek.t
May 26, 2008 12:53 PM
r1de4life
Feb 8, 2006 07:22 PM
slamed93si
Feb 3, 2004 06:13 AM
