b16 with p28 ecu rev limit at 7400?
Re: b16 with p28 ecu rev limit at 7400? (nxvictim)
chip your ecu because it is still running off of the D16z6's fuel maps/ignition timing and this is why your rev limiter is set at 7400
#1 Super Guy
Re: (nxvictim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nxvictim »</TD></TR><TR><TD CLASS="quote">... what kind of base maps are used for the b16's?</TD></TR></TABLE>
The OBD-1 B16A runs on a P30 map...
You probably shouldn't be running your B16 on a stock P28 since the two motors have very different fuel requirements. The B16 is capable of inhaling much more air than the D16 which means it needs more fuel.
At best, the B16 comes with larger injectors which means the stock P28 program is simply running it rich and loosing lots of power and clogging your cat.
At worst the B16 has the same size injectors as the D16 and the P28 map is starving it of fuel causing it to run lean and detonate (which may blow the engine). And since the P28 doesn't utilize the knock sensor on the B16, the ECU won't know to retard the timing if detonation is present...
Get that ECU chipped...
yeah.. it sounded like it was limiting out too early.. then i got my new tach hooked up and it was doing just that.. and im not really familiar with ecu's and **** so thanks for your help.. can i get the p30 map put inmy ecu?
also where are the best vtec transitions at? cause im gonna have it limit at 8400 and i was thinkin about getting the transtion at 4400 but im not 100% sure.
#1 Super Guy
Re: (nxvictim)
4400 is too low. You want it around 5300 or even later. If you switch too soon, you will be losing torque...
Yes you can have the P30 base-map put in your P28, but your going to have to have someone chip it for you. Contact Kenji as he's really good, reputable and has quick turnaround (most of the time).
https://honda-tech.com/zerothread?id=1300672
PS: Just make sure you only run premium fuel as the P28 ECU cannot utilize the knock sensor no matter what map is installed. This means it won't retard ignition timing for bad gasoline...
Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">Why would you run an ITR map on a B16? That's still not optimal...</TD></TR></TABLE>
Exactly. looks like he did not even read that big paragraph you wrote him. idiots
#1 Super Guy
Re: (.Hatches.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Hatches. »</TD></TR><TR><TD CLASS="quote">
Exactly. looks like he did not even read that big paragraph you wrote him. idiots</TD></TR></TABLE>
It happens...
It happens...
im sorry i asked for your guy's help.. my bad.. the map runs way better than before... so it did something right.. when i get my **** im gonna get it tuned then everything will be nice.. sorry for wasting your precious "time"
the ecu was from a shop and was pre-based.. so yeah.. when i get my cams, intake mani, headers and other **** im gonna get it tuned so its not like its a permanent base..
