My F23/H22 87x97mm H2B Build
This is my little write-up of my F23/H22 build. I am building this motor for my 91' Civic HB. This car is NOT my daily driver, it is used merely for drag racing as well as some street action.
I will try and keep the thread updated as much as possible. Here's the breakdown:
CAR: 1991 Civic DX HB
ENGINE: F23A bottom end / H22A Head
TRANNY: JDM B16A S1
I am using 87mm K20 pistons and the 97mm crank which will yield 2306cc.
I am going to begin the building phase soon, I will be setting the motor in the car for mock-up before the block goes to my machinist. I will provide further information and pics later.
Patiently awaiting...
Modified by jdm_ef9 at 7:36 AM 3/18/2008
TRANNY: JDM B16A S1
Re: My F23/H22 87x97mm H2B Build (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR »</TD></TR><TR><TD CLASS="quote">Nice planned build . . . </TD></TR></TABLE>
Thanks... always a good thing to plan and do your homework when building something to this extent.
Re: My F23/H22 87x97mm H2B Build (jdm_ef9)
Got a complete F23A longblock for $100. Here is the block(before bead blasting):
MMMMM.... 55mm mains:
Picked up a complete H22A4 longblock for $200 - just had a bad crank. Here is the head:
Re: (2fast4u831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 »</TD></TR><TR><TD CLASS="quote">nice!! </TD></TR></TABLE>
x2
x2
Re: (AdamB18C1EK)
thanks for all of the comment guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK »</TD></TR><TR><TD CLASS="quote">what are your plans for cams</TD></TR></TABLE>
i will be running approx 12.5:1cr and pro3 cams.
some of my parts are staring to arrive... i will get pics up soon!
also, the engine is getting mocked up tonight and i plan to drop it in to see what the clearance is like. stay tuned!
is it safe for a piston travelling in a clockwise direction to be put into a motor working in the opposite direction?? custom cp pistons only ran me 600$ for an H22(89mm, 12.5 static cr. for 54 cc chambers)
definitely subscribed for this build up keep us posted comrade
Re: My F23/H22 87x97mm H2B Build (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 »</TD></TR><TR><TD CLASS="quote">is it safe for a piston travelling in a clockwise direction to be put into a motor working in the opposite direction?? custom cp pistons only ran me 600$ for an H22(89mm, 12.5 static cr. for 54 cc chambers)
definitely subscribed for this build up keep us posted comrade </TD></TR></TABLE>
safe.... i would say yes.
oem reliable.... not so much but you cant really expect that when building something like this.
i worked with jeff from blueprint and got a set of trick wisecos.
Re: My F23/H22 87x97mm H2B Build (accordm3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordm3 »</TD></TR><TR><TD CLASS="quote">Nice build. I am going to emulate this setup when if you put down over 250 </TD></TR></TABLE>
Thanks
Well, it wasnt easy but the engine is in(temporarily)! There are a few mods to the chassis I have to make before it goes in for good. I snapped a few teaser pics:
Hood clearance
Thanks
Hood clearance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 »</TD></TR><TR><TD CLASS="quote">time to get the grinder and zip wheels out...lol that thing will look like a beast in that chassis</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 »</TD></TR><TR><TD CLASS="quote">that thing will look like a beast in that chassis</TD></TR></TABLE>
yes it will
yes it will
Re: (BlkChryKord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkChryKord »</TD></TR><TR><TD CLASS="quote">Interested in what work was require to run the K pistons in the F23.</TD></TR></TABLE>
Really all depends on what you are doing... With the K20 and F23 having the same compression height it makes for a fairly simple swap. If you plan on running a high cr or high lift cams then a little more work is required with the pistons.
