K20z1 help bleeding clutch!!
Old Mar 4, 2008 | 07:15 PM
done's Avatar
Default K20z1 help bleeding clutch!!
2005 K20z1 engine
2005 K20z1 slave cylinder
Tilton Master Cylinder (had twin disc b-series)
Using -4an 3 feet stainless line
For the life of me I cannot get it to build pressure. I cant even get it to suck up fluid out of the reservoir. I have tried a vacuum pump (used for pumping fluid out of 1 gallon buckets.
Also have tried this method: Valve open in cup of clutch fluid, and pumped all day long. closed valve, still will not work. any ideas?
Old Mar 4, 2008 | 10:22 PM
done's Avatar
Default Re: K20z1 help bleeding clutch!! (done)
Problem solved. Removed it to find out it was clogged up. Clean it with a towel, and no issues now!
ExTim
Feb 15, 2010 04:43 PM
ttcheung97
Aug 17, 2009 05:45 PM
delsolsi193
11
Apr 7, 2009 09:46 AM
924doorEG
Jul 16, 2007 05:31 AM
-Gambit-
Feb 17, 2003 12:45 PM
