99....2000....& 2001 type r computer.
Old Mar 1, 2008 | 11:15 AM
2mansi's Avatar
Default 99....2000....& 2001 type r computer.
Ok guys I have a 2000 civic si with a complete gsr swap. I rcently installed a blox type r replica intake manifold, itr throttle body, itr throttle cable with bracket, itr injectors, ctr cams with toda cam gears, jdm 4-1 itr header, and some other goodies. Well my friend recently decided to go k series in his 01 itr and being the best friend that he is he gave me his computer. Well I found out how to take out the imobileizer and tried it on my car but it wouldn't stay on.
My question is can I use 01 itr computer or do I need a different year. Also is this possible at all with any usdm itr computer.
Thanks in advance guys
Old Mar 3, 2008 | 06:21 AM
2mansi's Avatar
Default Re: 99....2000....& 2001 type r computer. (2mansi)
SOMEONE PLEASE HELP ME.....LOL
Old Mar 5, 2008 | 07:22 PM
Blown90hatcH's Avatar
How did you remove the immobilizer?
Old Mar 7, 2008 | 07:18 PM
mesach0's Avatar
On the A Connector of your wire harness you have to move A16 over to A15 and that should solve your problem. Good luck.
Old Mar 8, 2008 | 09:10 AM
98 eK4 siR's Avatar
Banned
Default Re: 99....2000....& 2001 type r computer. (mesach0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mesach0 &raquo;</TD></TR><TR><TD CLASS="quote">On the A Connector of your wire harness you have to move A16 over to A15 and that should solve your problem. Good luck.</TD></TR></TABLE>
??? TRUE ???
Old Mar 8, 2008 | 12:19 PM
mesach0's Avatar
Default Re: 99....2000....& 2001 type r computer. (98 eK4 siR)
Yes. I'm currently running a obd2b p73 in my 99 civic ex. I repinned the plug and it works. I have to let the fuel pump prime before I start the car everytime though. If you can find a pinout diagram of a obd2b ecu then you will see where the integra uses a15 for the fuel pump instead of a16(civic). Hope this helps you.
brianmcivics
Mar 30, 2008 09:21 PM
2mansi
Mar 2, 2008 03:42 PM
keepin'it_real
Apr 8, 2006 07:50 PM
clayj
Aug 7, 2003 02:46 PM
RAWB
Jun 4, 2003 11:59 PM
