Will this PCV system work? Need help fast....swapping next week.
I was wondering if this PCV setup will work. i'm building an OBD2 b18b1 block with a GSR vtec head...the block doesn't have a breather chamber box behind the block where the PCV attaches to...unlike obd0 and obd1 b18a b18b blocks. i tried to put the stock obd1 b18b1 breather chamber onto mine but didn't fit, which means i would have to bore the bottom hole bigger and i don't wanna do that.
I was thinking to drill a hole where the stock location is at on obd1 blocks and put a male plug there and then attach a hose to a PCV and from there to the intake manifold. Here's a pic of what I'm trying to say:
Should i attach a catch can somewhere along the line? or will i get by without a CC..?? I'm planing on Boosting about 15 psi with t60 in the future. Any help would help greatly....need info's before i do the swap.
Re: Will this PCV system work? Need help fast....swapping next week. (95dcsleeper)
will the thing is that there's no hole to start out with so i have to drill
egsickz0
15
02-28-2009 08:11 PM
Help- OBD2 GSR bottom end, OBD2(was in a OBD1 car) head- need help with some of the coolant lines an
vestalfootball72
12-12-2006 08:12 AM
