LSVTEC unreliable?
Old Feb 20, 2008 | 09:57 AM
ej6hatchie's Avatar
Default LSVTEC unreliable?
ive been looking up about the LSVTEC, my cousins say its a good engine all around. but ive seen posts where people say this swap is unreliable and dies at random times. any thoughts?
Old Feb 20, 2008 | 02:49 PM
sirtef9's Avatar
Default Re: LSVTEC unreliable? (ej6hatchie)
The unreliable ones prolly have 200000 miles on the block and 175000 miles on the head, build one right and no worries.
Old Feb 20, 2008 | 06:53 PM
BigJ5's Avatar
You get what you put into it. If you use a junkyard block with a beaten oil-stained head, your luck will run out soon.
Use your head when you get your parts. Do a clean and proper build and your golden.
My LS V runs great.
Goodluck!
Old Feb 21, 2008 | 09:46 PM
AdamB18C1EK's Avatar
Default Re: LSVTEC unreliable? (BigJ5)
search...there are countless threads covering this topic
Old Feb 22, 2008 | 04:35 AM
StorminMatt's Avatar
Default Re: LSVTEC unreliable? (AdamB18C1EK)
Here's something else to consider. Even if the engine is in good shape, you can't expect a reliable setup from some slopped together deal. If you just slap a B16A head on an LS bottom end, you are NOT going to have a reliable setup. The LS-VTEC has gained a bad reputation because ALOT of people look to this setup as a cheap way to get a 1.8 liter VTEC. But if you do it cheap, it is NOT going to be reliable.
Old Feb 22, 2008 | 09:45 AM
ej6hatchie's Avatar
thanks everyone for their responds. yea im thinking of getting a b18b from PWjdm and buying my friends 2000 civic si b16 head, the head only has .. 50k miles on it and he recently swapped to a gsr. ill post pics of the parts after i get all the components.
trompeta performance
Mar 14, 2008 10:00 PM
mcgee*
Nov 14, 2006 09:26 AM
elrandeeto
Nov 15, 2004 10:47 PM
granada_sun
11
Jul 2, 2003 09:43 AM
Sean K
Dec 16, 2002 08:16 PM
