compression test wet and dry.
ok, got a 82mm lsvtec with ITR piston(us) and stock b16 head. my compression was 245 across the board, but now its around 220. i know there is a reason for the loss, but i added oil to the cylinders and the compression shot up to 320, which it has never been there before.
the engine smokes sometimes in high rpms, but mainly in between shifts or after high vacuum situations(i assume its valve guides since the heads got 270k+ on it and suffered a few bent valves) but now im wondering if it could be rings, but the engine was just rebuilt no to long ago using new parts are everything came to spec, now im wondering if the oil just filled the cylinders more and cause the jump in pressure because of the decrease in cylinder volume.
Re: compression test wet and dry.
im hoping its just the ring, i dont feel like blowing alot of money in the head. rings would be easier and faster
because if it was valves the compression wouldnt have changed?
Im not ruling out the valve stem seals completely, but I commonly see the oil control rings with issues. Especially with cheaper rings. How is your PCV system?
how much oil are you buring? i was thinking crankcase pressure since you got ls rods with b16 bearings so your really not getting any oil on tha cylinder walls,even if you had bad oil control rings. but you said you got a catchcan so im puzzled.are you using the block fittings or just the valvecover fitting? in my experience valve seals/guides will cause smoke but not that much oil consumption,where oil control rings will cause lots of oil consumption.
im just using a breather on the valve cover.
found the problem
3 blown pistons. cars been having these problems, since right after building it. i ran a 100mph trap with this engine in this condition....
another set of ITR pistons. dont want anything special with this engine anymore. just want the damn car to run and not break.
i just need to find a set of 82mm itr
yea, those are suppose to be npr pistons which are the oem pistons, but i dont think so. the ringland break is identical on all three of the damaged pistons. no cylinder wall wear or maring, just a few broke rings from the blown lands.
im hoping good things from the rs pistons, im just paranoid.
im hoping the pro's will have good things to say about them
i dont blame you for being paranoid. really thats your only option with that bore unless you go with forged. ive never seen or heard anything bad on any site about rs pistons. i doubt there the same as npr.last i heard they came with hasting rings,and the npr's dont.at least you caught it before your cylinders got scared up.
they got marks on them, but the crosshatch is still there.
****ed up part is i just ordered cp 82mm rings for 104, and i can upgrade to the same rings with the rs kit with pins and the pistons, rings, pins and shipping would be 215.
yeah thats messed up. could you cancel the order? i know mar77c on here has the rs 81.50 pistons and rings in his gsr block for several years now and he's makeing 226whp. his compression and leakdown #'s are still very good.
yea im going to try and cancel my order tomorrow after i order the rs pistons. i think i got ripped off on these pistons i think the were nippon racing instead of npr.
i just want to run the hastings rings with the pistons and call it a day. people told me that it was detonation that caused the damage, but i see no damage on the piston indicating it was detonation. no damage on the plugs or anything. to me the engine was burning fine.
idk...im not a tuner or anything. maybe someone will chime in with that experience. you wasnt running aftermarket cams was you? also was it tuned?
it was afc tuned later in the engines life, but the car was origionallly broke in and driven on a map from a similar engine. same bore itr pistons ls/vtec on stock cams.
when it was first built i heard pinging and i guess i was too late on getting into the map to pull timing, and thats where the issue came from.
well,at least we know they wont take much!!! this time i would invest in a street tune,on at least crome or something. i dont think tuners charge much just for a street tune
yea, i neglected that for to long. ive got a tune set up once i get done rebuilding it. i just have to figure out if blown ringland would cause oil/air/fuel mixture to circulate into the intake manifold and cause wet valves
Droppedatbirth!
15
02-02-2004 06:36 AM
