How to swap d16y7 into d15b7..
Guys, part swapping newbie here, I have a wore out b7 in 95 with manual tranny. I have access to a nicer d16y7 from a 98 Civic. Will the d16y7 motor bolt up to the 95 manual tranny. Can i pull the intake, accessories, wiring harness from the d15b7 and boltem up to the y7 motor and it all bolt up. Just wanting to get a good runnin stocker going again. Read the FAC and hybids swaps but failed to find this info..thanks.
Technical Hero
Re: How to swap d16y7 into d15b7..
Will bolt in and up to your transmission. You may have to swap the drivers side timing belt block mount from the B7 to the Y7. Swap over intake (including injectors) and exhaust manifolds as well. Reuse your B7 wiring harness, alternator and distributor. The rest should plug and play. Your ecu will run it fine.
