Quick LsVtec question
Old Nov 16, 2014 | 01:22 PM
Jthw's Avatar
Default Quick LsVtec question
Hey, I was just talking to a guy trying to sell me some pistons and rods for my lsv build. In a lsvtec are the rods supposed to be non vtec or are they supposed to be vtec rods? They're eagle rods with cp pistons, arp rod bolts going into my b18b bottom end. Is having non vtec rods correct ?
Old Nov 17, 2014 | 08:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Quick LsVtec question
If your B18B short block is stock (un-modified), then yes, LS rods would be used. The important detail to keep in mind to answer your question is you use the rods that match the crankshaft... the two parts combine (crank and rod) to meet the proper height for using a standard "B" series piston. You can use a GSR crank (de-stroke) in your B18B block, but you would have to use the GSR rods as well, not the LS rods.
nyceli
Mar 11, 2009 09:32 AM
94teg2.0
Mar 14, 2007 09:20 PM
toooslow
Feb 1, 2005 08:18 AM
BigPlansNoMoney
Nov 18, 2004 11:14 AM
88CRXHybrid
Apr 28, 2002 07:12 PM
