limp mode no codes
Old Oct 17, 2014 | 12:01 PM
99 SI TYPE R's Avatar
Default limp mode no codes
When i first start the car after its been sitting for a long period of time generally over night runs perfect but after about 5 minutes limp mode kicks in ive tried several times checking for codes and Nothing cel light comes up after those 5 minutes while driving it. Its a 94 gsr head obd1 ive researched limp mode for countless hours and havent havent found any problem like mines also does it matter since my car is a 99 and engine is obd1 could that be a reason of no codes when jumping the two wires
Old Oct 18, 2014 | 02:46 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: limp mode no codes
Does your check engine light work?
Old Oct 18, 2014 | 06:18 AM
Yes it does i noticed today that it the cel kicks in once it reaches normal operating temperature
Its has a p72 chipped no o2 sensor but used to run fine before until recently
Old Oct 18, 2014 | 02:12 PM
Technical Hero
Pull the code with the car running next time it comes on
Old Oct 20, 2014 | 01:36 AM
NeedmoPowr's Avatar
Fuel pressure problem
Old Oct 21, 2014 | 06:45 AM
HiProfile's Avatar
Limp mode with no CEL code (meaning solid CEL) means a bad ECU or bad chipping job. It could be intermittent due to a cold solder joint or just a spot that has excessive solder blobs around it. The last ecu that I repaired had a decent looking joint on the octal latch (smaller chip) yet the desolder job had burned the trace just next to the solder that caused it to throw a constant solid CEL.
The best thing to try is a different ECU, after that you'd want to re-burn the map to a different chip. Chips usually fail completely, not intermittently, but there's a chance.
Old Oct 21, 2014 | 09:23 AM
tony_2018's Avatar
Fish Twig
You can still pull codes even if its an obd1 ecu, jump the 2 pin plug near the ecu, should be above the ecu, and your cel light should blink. If you can't decipher it please post video.
Speed94
Nov 6, 2006 06:35 PM
buh_buh
Jul 27, 2006 03:11 AM
colombian linx
Mar 15, 2004 11:09 AM
dynamo
Sep 22, 2002 11:59 PM
