need help with d series swap
Hello I have a ek, I had a d16y7 non vtec but I decide to swap it for a d16y8 vtec, I intall the d16y8 with all the harness and computer, now my car won't start, I have spark but no fuel, I have no power to fuel pump, what can I do?
Technical Hero
Re: need help with d series swap
You can't use that harness or any other 96-98 as they have different ECU connectors, you must either use your factory harness and add the additional wiring (VTEC, knock, 3-2 wire IACV, extend secondary 02 and use your original distributor for plug and play or an distributor adapter harness) or you can use a 99-00 EX harness and then wire in the secondary 02 manually to the ECU and reuse your original distributor as the plugs differ.
Jvelez1216
03-14-2016 08:51 PM
