93 Si LS swap..
Re: 93 Si LS swap..
you will need an obd1 intake manifold and tb. you cannot have any extra wires/plugs hanging, so i advise you to use an obd1 ls harness too. also a p75 ecu.other than that everything must be stock (stock fuel rail, cannot use a FPR guage, STOCK!). make sure your timing is correct. and make sure your idle is correct too.
str8drift
10-31-2007 03:34 PM
