b18b1 swap into 2000 civic DX
Hi everyone,
Im doing a b18b1 swap into a 00 civic DX. This is my first honda swap. Can anyone tell me if everything is correct on my parts list and also what to look out for?
Engine:
B18b1 block from 94 integra: Bored to 82mm, 10:1 Comp. Ratio cast pistons
ARP rod bolts
ARP head studs
Lightweight crank pulley/ lightweight pulley set
Adjustable Cams
99-00 si b series T-bracket
95 integra rs Pr4 head: running p75 OBD2b ECU on stock dx harness.
Dizzy plug conv. Wire. OBD2 8 pin to OBD2 10 pin: RYWIRE.COM
97+ CRV ac compressor/ps pump brackets from b20: Will integra b18b belts work for these components??
Stock P75 intake manifold
Transmission:
B series s80 Tranny
D series tranny mounts
94-01 integra shift linkage
Any B series halfshaft's?
Stock flywheel and clutch kit 8-5/8", 24 splines
MISC:
Bigger radiator and B18 upper/lower Radiator hoses
Heater hoses for rear of block
I know so far I will have to move fuel pin from a16 to a15, conv IACV from 3 wire to 2 wire, IAT moved to intake arm, Extend 2nd O2 sensor.
Also, my Civic DX is a 5 speed d16y7 currently. Im not looking for crazy power just a strong DD for myself.
ANY help is greatly appreciated!!
Engine:
ARP rod bolts
ARP head studs
Adjustable Cams
Transmission:
B series s80 Tranny
MISC:
aaronboy123
04-17-2009 07:16 PM
