99 honda crv engine swap help
Old 11-25-2014, 05:00 PM
Tommyfarr's Avatar
Default 99 honda crv engine swap help
what all has to be done to put a 90 Integra b18a engine in a 99 honda crv
Old 11-25-2014, 05:21 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: 99 honda crv engine swap help
A b20 can be picked up for pretty cheap, I wouldn't bother to be honest.
Old 11-25-2014, 06:46 PM
Tommyfarr's Avatar
I havnt been able to find a cheap b20 in my area and I already have the b18a and trying to save money
Old 11-26-2014, 03:28 AM
Technical Hero
If you have the original engine swap over injectors, alternator and distributor. You'll have to bypass the CKF (search for CKF bypass). You'll also have to wire the fan switch from the thermostat housing to the back of the block. Youll probably need to swap over the exhaust manifold from the CRV. You may also need to swap over the fuel rail from the B20. The transmission will bolt up. You should be able to use the mounts but you probably have to swap over the B20 timing belt mount (the one bolted to the block) over to the B18. You'll also need to swap over the B20 throttle body to the B18 as it has the MAP sensor on it. The knock sensor is going to be tricky as the B18 doesn't have a spot for it so you'll have to tap a block location. Like I said it's not a fun swap and a JDM replacement would be much easier.
miguel aguirre
06-04-2016 11:23 PM
rickscrx
11-28-2015 05:40 PM
eckolistik
07-13-2006 03:30 PM
kaspur_eh
04-29-2004 04:04 PM
burnett999
21
08-23-2002 09:25 AM
Quick Reply: 99 honda crv engine swap help
