which rear mount? ys1 cable in 93 civic
I have had the car for a while and the rear trans mount is not the correct one only one hole lines up and I am trying to get everything on my car 100% correct.
Its a ys1 ls trans on a b18.
As far asi can tell someone bent\cut the civic rear mount to make one hole line up
Which mount is the correct one? The one from a 90 93 teg?
I have searched but can not find a firm answer.
Re: which rear mount? ys1 cable in 93 civic
The proper bracket is from a '94-01 Integra. You will need to use the smaller 12mm bolts (17mm head) from the cable trans in the larger holes thru the bracket, but otherwise, all works as advertised.
existanzcivicb20
05-09-2017 06:18 AM
CapnKrunch
09-01-2010 07:19 AM
