H2b
Old Sep 18, 2014 | 03:01 PM
Avery Bain's Avatar
Default H2b
I'm trying to buid a h2b setup I have a qsd kit
Eagle rods
Mahle pistons
Bc springs & retainers
Bc stage 3 cams
Skunk 2 intake
I'm looking for some advice or some pointers on my build
Old Sep 18, 2014 | 03:19 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Re: H2b
Eagle rods
Mahle pistons
Bc stage 3 cams
Skunk 2 intake
Will you be boosting? What are your goals?..Track or street setup? Need more info man
Old Sep 18, 2014 | 05:52 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: H2b
Check the H2B stickies in the hybrid section, tons of information also search for the official h23vtec thread. Seems to be the best choice for forced induction and N/A.
Old Sep 19, 2014 | 11:46 AM
Canadian_EF's Avatar
Default Re: H2b
I've got this swap in my Civic right now.
I didn't have to cut the frame rail, but you'll need to delete the balance shafts, and get the balance shaft pulley machined down into a spacer. the fitment is tight, i can't change my alternator belt without removing my driver side mount.
Old Sep 19, 2014 | 02:13 PM
Charlie Moua's Avatar
Default Re: H2b
kiss
swap in a low milage stock jdm h23 , get it running right, then go from there
Old Sep 20, 2014 | 01:54 PM
Steve at Heart
Default Re: H2b
If you order the KStuned balance shaft eliminator kit it comes with a new spacer. Otherwise there is a a spacer in the h2b sticky that can be used.
H2B FAQ click here
H2B Discussion thread click here
Old Sep 21, 2014 | 01:09 PM
Default Re: H2b
H2B FAQ click here
I made a balance shaft delete for under $20.
The machine work for the balance shaft pulley, plus getting the crank pulley machined down into a single pulley, cost about $60.
It's a little more cost effective and functions the same.
There's a $20 balance shaft delete thread somewhere.
Old Sep 21, 2014 | 01:20 PM
Steve at Heart
Default Re: H2b
I have seen the $20 thread. Which crank pulley are you using? Any pictures of frame rail clearance? Are you using a kit?
Old Oct 12, 2014 | 06:50 PM
Dorkenheimer's Avatar
Default Re: H2b
There's an official H23vtec thread!?? *gasp*
Old Oct 13, 2014 | 05:56 PM
Steve at Heart
Default Re: H2b
Its in the prelude section.
H23 Vtec Thread
Old Oct 14, 2014 | 08:31 PM
Default Re: H2b
Huh....I looked for it and couldn't find it. Think I searched the wrong thing. I like that thread a lot, very handy. Saved it of course!
Old Oct 17, 2014 | 07:37 AM
HiProfile's Avatar
Default Re: H2b
Originally Posted by Charlie Moua
kiss
I feel the same. It seems like half the H2B'ers try this as their first swap and can't even get the simple stuff straight. Toss in a stock motor & build another on the side if possible.
If you are going NA, most people can get >250whp with a bone-stock bottom end. You definitely need to give more info on what car you have, what your goals are, etc.
Old Oct 17, 2014 | 04:46 PM
Default Re: H2b
I'm using the qsd kit. Innovative alternator relocation kit, h22 alternator w/ D series pulley
Accord f22 crank pulley machined, ac and ps removed
I also had a few mm taken off the crank side. It barely fits. I'm using the hardest urethane mounts from innovative so it hasn't rubbed the frame rail yet.
Old Oct 19, 2014 | 08:11 AM
Default Re: H2b
does the d series pulley on the H alt change the output of the alt at all?
Old Oct 19, 2014 | 01:35 PM
Default Re: H2b
I still get proper voltage at the battery while the car is running, so I don't think so.
Old Oct 19, 2014 | 09:49 PM
Default Re: H2b
Hmm, good to know. I should just measure the H23ABT alt pulley and my d series alt pulley just for poops.
Old Oct 20, 2014 | 12:15 AM
Steve at Heart
Default Re: H2b
Canadian- Thanks for the pictures.
Old Oct 21, 2014 | 06:39 AM
HiProfile's Avatar
Default Re: H2b
They all look to be 60mm. I couldn't get right up to my D16 pulley, but the H23A and B18 pulleys I measured were 60mm. You have to get a good 25% undersize before voltage gets low at a normal idle.
Old Nov 1, 2014 | 10:40 PM
Default Re: H2b
Really? I JUST measured my H23A alt pulley, and it came in at 2 and 5/8".
My B18 alternator pulley came in at 2 and 3/8".
Old Nov 23, 2014 | 06:54 PM
gmcuajo1's Avatar
Default Re: H2b
I see that you don't have the AL spacer that should be used when remove the balance shafts.
That is because you are usisng the alt relocator, or your pulley doesn't need it, or anything else?
Old Nov 23, 2014 | 07:01 PM
gmcuajo1's Avatar
Default Re: H2b
Another question:
If you use the alt relocator it goes where the A/C compressor should, right?
What if I want to have A/C? Will be able to left alt and A/C where they should be from factory without having problems with belt or pulleys hitting the frame?
I am doing a 93 del Sol, EG, which have very similar (if not the same) engine bay of 92-95 civics and 94-01 integras. Want to have A/C. Please advice.
P.D.
Live in PR (caribbean) A/C is used all time of the year.
Old Nov 24, 2014 | 05:34 AM
Default Re: H2b
With the alternator relocation, the alternator is moved down to the AC spot, and moved over about a half inch to clear the frame rail. I do have a spacer, but it sits inside the pulley, so you don't really see it. Here is my spacer, pulley, post mount, and hood spacers.
Another question:
P.D.
The stock alternator bracket and alternator don't fit, the alternator pulley would be inside the headlight bracket if you did it this way. I don't know if anyone has AC and the H2b in an EF. That would be impressive to accomplish.
Old Nov 24, 2014 | 08:11 AM
gmcuajo1's Avatar
Default Re: H2b
Thanks for your reply.
Will have make something to have both, H2B and A/C.
Old Nov 24, 2014 | 08:15 AM
gmcuajo1's Avatar
Default Re: H2b
Does anyone have an H2B (EG, EK, EJ, EF, DC, EM1) without alternator relocation, or A/C on it?
Using QSD H2B kit.
Please post pics.
Old Nov 29, 2014 | 10:17 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: H2b
I've got AC.
MuscleByRussell
11
Oct 12, 2008 08:55 AM
music462
Sep 1, 2008 11:19 AM
dk4ever
Oct 22, 2007 10:19 AM
Sorcereryk
Oct 22, 2003 01:56 PM
