Difference between d15b vtec and vtec e
Old Sep 11, 2014 | 12:34 PM
FirstCRX's Avatar
Default Difference between d15b vtec and vtec e
I have been looking at threads and can't find the answer I need. Everyone just keeps posting the power and specs on the motor. I bought a vtec motor but I want to confirm which one it is. It has one vtec solenoid so I know it's not a 3 stage vtec but how can I tell if it's a true vtec? Thank you.
Old Sep 16, 2014 | 02:34 PM
94EG8's Avatar
Seagull Management
Default Re: Difference between d15b vtec and vtec e
The D15B vtec-e is aside from the block stamp simply a D15Z1 VX engine. The D15B Vtec doesn't directly correspond to anything, but it's similar to a D16Z6 Si engine (same head, intake and exhaust manifolds, same rods)
The intake and exhaust manifolds will give it away at a glance, but if there's some doubt that they're not original to the engine pull the valve cover, if it's got roller rockers it's vtec-e, if not it's a regular vtec engine.
Old Sep 22, 2014 | 12:09 AM
FirstCRX's Avatar
Thank you. I was able to confirm it was a regular vtec. One question is with the vtec solenoid. I noticed it was damaged. Is it the same as a d16?
h4mza
Feb 22, 2013 10:13 AM
feriotypeR
Jun 4, 2009 09:42 AM
sh3d3vilinme
Feb 4, 2009 08:39 PM
asphalt788
Aug 29, 2008 10:24 PM
Goose
20
Nov 3, 2003 09:16 AM
