went to know about sohc zc to a ztec
went to know about sohc zc to a vtec
any one know if i can and what i need and what head to use so any infor would help
Modified by dom91si at 6:48 PM 6/17/2004
Re: went to know about sohc zc to a ztec (dom91si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom91si »</TD></TR><TR><TD CLASS="quote">went to know about sohc zc to a ztec</TD></TR></TABLE>
It's gonna be some work to go from a SOHC ZC to a Ford motor....
if you're talkin VTEC sohc then it's the same as D16Z6
if you're planning on running the JDM ECU then you can run your stock 02 sensor and avoid all the extra O2 sensor wiring and the VTP VTEC pressure sensor (most JDM ECU's don't read this sensor)
