obd2 h22a fuel injectors in obd1 h22a? help
i purchased some 310cc injectors for my obd1 h22a accord last winter, car was stored and was not able to finish project. took out the car and just found out that the injectors were for obd2 h22a. i customized the injectors to fit the wiring harness and was wondering if i needed to cut the harness and switch the wires around, because a buddy of my owned a 2001 gsr and to do his obd2 conversion to obd1 injectors he had to switch the wires on his harness around?
Re: obd2 h22a fuel injectors in obd1 h22a? help (toyota)
so i should get rid of the resistor and cut and rewire the wires to a 12V? could you give me a detailed explanation. thank you very much
allen8908
03-26-2009 04:03 PM
