B18B into 98 Civic wiring question. Search function not working.
I have been doing some research over this swap and was curious what wiring modifications are needed to install a B18B into a 1998 Civic DX. The motor is OBD II. I would think that nothing would be needed to modify if I use the Civic harness over. Please correct me if I'm wrong.
I know this question probably comes up all the time, but the search function doesn't seem to be working.
Thank you,
AJ
Thank you,
AJ
Re: B18B into 98 Civic wiring question. Search function not working. (Aahj)
i have the same exact set up except mine was obd1 so i have to get a conversion. but u shouldnt have any problem plugging them up with ur harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aahj »</TD></TR><TR><TD CLASS="quote">I have been doing some research over this swap and was curious what wiring modifications are needed to install a B18B into a 1998 Civic DX. The motor is OBD II. I would think that nothing would be needed to modify if I use the Civic harness over. Please correct me if I'm wrong.
Thank you,
AJ</TD></TR></TABLE>
You WILL have to perform the IACV fix if you plan to reuse your DX engine harness on the B18B engine because the B18B engine uses a 2-wire IACV and your DX engine has a 3-wire IACV.
You can find the info on how to fix your IACV if you click on the "technet" link in my signature and look under ecu + wiring for OBD2a vehicles.
Also, you'll have to swap over to an integra CKF plug.
That's about it though.
Thank you,
Re: B18B into 98 Civic wiring question. Search function not working. (Katman)
Katman,
That information is great. Thank you!
Now since we are on the subject, I have a couple of other questions about this particular swap.
- Shift linkage: Integra shift linkage will work, correct?
-Motor mounts: I need to use a 99-00 Civic Si rear motor mount bracket. Are there any other mounts that I will need to change over?
-Exhaust: Will the stock exhaust manifold and downpipe from the B18B bolt up to the DX b-pipe? If not, is there any combination of b-pipes/downpipes that I could use so I don't have to take it to an exhaust shop?
Is there anything else that I'm missing? I'm trying to make sure I'm completely prepared for thie swap before I get into it.
Thank you very much for your time. Your website about the wiring is awesome.
Thanks again,
AJ
Thanks again,
AJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aahj »</TD></TR><TR><TD CLASS="quote">Katman,
-- yer welcome
-- that's an affirmative
-- Top tranny mount, you'll need to reuse your existing EK SOHC top tranny mount and you'll need to convert the timing-belt side mount over to an Si coupe's mount, if the B18B doesn't have a dual-post mount...if that makes any sense to you. All 94-01 integra's use a 3-post mount which is incompatible with EK's 'bridge mount'. Here's an image to show the dual-post mount:
-- Now, the B18B exhaust manifold will not mount up to a DX B-pipe because of the catalytic converter being in a different location in contrast to a B18's cataytic location. You'll definitly have to visit a muffler shop once you get the swap B18 in your DX. If you can get the b-pipe & cat from an LS integra, it will bolt up to your civic.
-- other that what I've explained about wiring, that should be it..
Thanks again,
-- yer welcome
Thanks again,
Katman,
Again, thanks for the help. I'd say I'm completely ready to take this on.
If I have anymore questions, I definitely know who I'll be contacting.
AJ
AJ
Arthas
27
08-17-2010 08:42 PM
hotcivicsi
01-08-2009 06:50 AM
