Cluster Swap Question
Old Jun 17, 2004 | 07:41 AM
xJ.SLOTHx's Avatar
Default Cluster Swap Question
Ive been reading up on archived information and material but couldnt seem to find an answer for my question. Im planning on doing a JDM ITR cluster swap into my 94cx. Well anyway, I have the pinout information that I need, but I was wondering as to if having a pre 98' JDM ITR cluster or 98'+ Cluster would make any sort of difference what so ever as far as having the cluster work properly considering the wiring diagram/info i've obtained from here:
https://honda-tech.com/zerothread?id=504396
Thanks in advance.
-ian
Old Jun 17, 2004 | 12:51 PM
TotalJDM.com's Avatar
Default Re: Cluster Swap Question (ian)
You will need to rewire alot of stuff. It's not tough or anything, but it's not plug and play. Acquire the wiring diagrams for your clips, and the cluster.
As for fitment, you will need to get your plastic tram remolded to accomodate the new cluster, since it's longer/winder and more rounded off than your current one.
Good luck, should be fun.
Andre
andre@totaljdm.com
Old Jun 18, 2004 | 07:59 AM
xJ.SLOTHx's Avatar
Default Re: Cluster Swap Question (TotalJDM.com)
cool thanks alot
burnykawizzle
Apr 27, 2010 07:55 AM
D-Money
Aug 7, 2006 01:21 PM
import810
Dec 21, 2005 08:36 AM
jfoster
Nov 13, 2005 04:46 AM
