need help doing a Gsr swap on 96 civic
I'm doing a swap a 95 gsr into a 96 civic ex i was wondering what mounts would i have to change and what wires under the hood do i need to change i already use a obd2 to obd1 harness on the ecu
Re: need help doing a Gsr swap on 96 civic (Silvereurocivic)
Mounts: - Si rear tranny mount
- Si left upper engine bracket
- Any 94+ Teg left lower A/C bracket
- GSR right lower bracket
Wiring: The only wires you need to add are the 2 Vtec wires, the IAB, and the knock sensor.
Do a search as most people will tell you. This topis has been covered numerous times. There's tons of info on this.
Read this article
Read this article
JDM99DC2
04-11-2005 02:08 PM
