crx wont start ls swap and obd1 swap
have everything stalled just wont start ecu throws 1 code engine coolant temp
sensor. Not really that big of a deal the car should atleast start. I have
compression, spark, and theres fuel pressure in the fuel rail. timing is right, my
only guess is that injestors arent recieving a signal, they came out of a working
car so they should work. any ideas?
Re: crx wont start ls swap and obd1 swap (cd1fidy)
Is this a CRX Si / HF or a DPFI Car? What engine are you running and with what harness? If your using the Si Harness with resistor box with OBD 1 you need OBD O ( NON OBD ) injectors. That could be your problem. The Si Harness with the resistor box needs the right injectors.
Re: crx wont start ls swap and obd1 swap (QUiKSR20)
88 crx si, with resistor pack running dsm 450 injectors with resitor pack, pr4 wiring harness, blownhatch's obd0-obd1 conversion harness, 94 ls ecu with uberdata chipped for boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd1fidy »</TD></TR><TR><TD CLASS="quote">88 crx si, with resistor pack running dsm 450 injectors with resitor pack, pr4 wiring harness, blownhatch's obd0-obd1 conversion harness, 94 ls ecu with uberdata chipped for boost.</TD></TR></TABLE>
Hmm Im not sure. Havent messed around with that combo. Maybe someone else can chime in with better ideas.. Good Luck with it.
dohccrxsi
10
08-18-2008 10:36 PM
gogosobewfew
10-18-2005 10:10 PM
