whats the compression numbers for the B16A2?
Re: whats the compression numbers for the B16A2? (VTECR021)
it should be in the 200 range. 120-150 is too low, that's IF they did it correctlly in the first place. sounds like a rebuild is in order.
Re: (LsVtec92Hatch)
yea mine put out 220-240 before i cleaned out all of the deposits.... then it tested around 200-220 across the board....comp tester best 35 bucks i spent....
