93 civic vx wiring
Re: 93 civic vx wiring (b204d)
The VX harness can be used for nearly any swap, especially for a DOHC VTEC B series motor. You will need to rewire for a 4 wire O2 setup, other than that it's as good as any other VTEC engine harness.
Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">get a p28 or even cheaper, a pr4.</TD></TR></TABLE>
Not following here.... a PR4 is an OBD0/OBD1 Integra nonVTEC B18A1 ECU. The VX ECU is made to run basically only the D15Z1 VX motor. Of course the ECU can be chipped like a P28 to DOHC VTEC specs though.
since he stated his intention was only to run on the ecu for a short while and then go with AEM EMS, i said the obd1 pr4 was an option only because it will run the car fine if he doesnt go nuts with it and they are pretty cheap.
gnar kill
10
11-19-2004 02:29 PM
dremmel
03-01-2004 09:17 PM
Motorvated
08-19-2003 01:33 PM
