cable/hydraulic tranny differences
Old Jun 17, 2004 | 06:33 PM
lunaticracing's Avatar
Default cable/hydraulic tranny differences
I have a '92 civic VX Hatch with a hydraulic five speed. i am looking to put a B16a1 in it but would like to keep a hydraulic tranny in it. from reading numerous post i have gathered that the trannies bolt up the same but no one has said anything about the computer. I guess my real question is, can you use a hydraulic tranny with a obd0 computer?
Also while i have your attention. if i decide to use a obd1 computer and a hydraulic tranny what would i have to do to the B16a1 to make it all work?
Any help would be greatly appreciated.
Old Jun 17, 2004 | 07:11 PM
VTECVillain's Avatar
Default Re: cable/hydraulic tranny differences (lunaticracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunaticracing &raquo;</TD></TR><TR><TD CLASS="quote">I have a '92 civic VX Hatch with a hydraulic five speed. i am looking to put a B16a1 in it but would like to keep a hydraulic tranny in it. from reading numerous post i have gathered that the trannies bolt up the same but no one has said anything about the computer.</TD></TR></TABLE>
Hopefully you aren't meaning that you can reuse the VX hydro tranny. The D series tranny's will not bolt up to a B series motor. You will need to get a hydro B series tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I guess my real question is, can you use a hydraulic tranny with a obd0 computer?</TD></TR></TABLE>
OBD has nothing to do with a tranny so yes you can use a cable or hydro manual tranny without regards to what ECU you use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if i decide to use a obd1 computer and a hydraulic tranny what would i have to do to the B16a1 to make it all work?</TD></TR></TABLE>
I'm assuming that you have or plan to get a first gen B16A. By the time you get a hydro tranny, all necessary OBD1 parts, etc. you will have as much if not more than what a second gen B16A costs. Either way, if converting an OBD0 B16A engine over to an OBD1 setup you will need - OBD1 ECU, injectors, distributor and alternator (can reuse OBD0 alt. if you rewire the plug).
Old Jun 17, 2004 | 07:14 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunaticracing &raquo;</TD></TR><TR><TD CLASS="quote">I guess my real question is, can you use a hydraulic tranny with a obd0 computer?</TD></TR></TABLE>
The ECU has no control over the manual trans. So you can run any ECU with any trans (within reason).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunaticracing &raquo;</TD></TR><TR><TD CLASS="quote">Also while i have your attention. if i decide to use a obd1 computer and a hydraulic tranny what would i have to do to the B16a1 to make it all work?</TD></TR></TABLE>
You would have to change the two post timing belt bracket motor mount out for a three post and run 94+ motor mounts. Reuse your harness or get a 94+ integra harness. and do obd0 to obd1 convertion.
EDit: a little to late
Old Jun 17, 2004 | 07:18 PM
Default Re: cable/hydraulic tranny differences (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">EDit: a little to late </TD></TR></TABLE>
LOL seems like we do this to one another every now and again...
Old Jun 17, 2004 | 07:24 PM
Default Re: cable/hydraulic tranny differences (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
LOL seems like we do this to one another every now and again... </TD></TR></TABLE>
*Starts to practice typing faster* The battle begins
Old Jun 18, 2004 | 01:14 AM
hondaZvic's Avatar
lol...
lunaticracing, i think they just nailed it for u.
slor209
Jan 14, 2007 11:04 PM
folta2169
Jan 14, 2005 11:02 AM
SL!M
Aug 30, 2003 09:28 AM
