Use stock prelude rear bracket for HASport motor mounts on H22 swap into EG?
the little instruction sheet that came with the "H-series into EG" HASport mounts said that i need to use a stock 92-96 prelude rear mounting bracket to put their mount on, but the civic one lines up with my HASport rear mount just fine, it looks like. is this definite? ive been searching for 10 mins so far, and im having to go through those multi-paged stickys, and im in a hurry to get to work so any help is very appreciated
Re: Use stock prelude rear bracket for HASport motor mounts on H22 swap into EG? (munk)
i see a few people saying you have to use it with HCP mounts, but still nothing yet on HASports
The civic rear bracket will not work, you have to use the oem 92-96 Prelude rear bracket..
Re: Use stock prelude rear bracket for HASport motor mounts on H22 swap into EG? (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">The civic rear bracket will not work, you have to use the oem 92-96 Prelude rear bracket..</TD></TR></TABLE>
thanks, i found references to that but i never saw anyone flat out say it in all the threads i found. just wanted to see it.
fabe85
06-23-2007 06:18 AM
