crx with b18a1
Old Jun 17, 2004 | 02:52 PM
one8toh8's Avatar
Default crx with b18a1 need help with some parts
I have a 89 crx si and it has a 90 integra ls b18a1 motor in it and, I am just wondering if anyone has done this and if they did, what axels where used? Also what throttle cable,and clutch cables where used?
Modified by one8toh8 at 1:10 AM 6/18/2004
Old Jun 17, 2004 | 07:28 PM
VTECVillain's Avatar
Default Re: crx with b18a1 need help with some parts (one8toh8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one8toh8 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 89 crx si and it has a 90 integra ls b18a1 motor in it and, I am just wondering if anyone has done this and if they did, what axels where used? Also what throttle cable,and clutch cables where used?</TD></TR></TABLE>
I have a 91 CRX with a 96 B18B1 which is just a revision of the B18A1. For driveshafts I'm using the 90-93 Integra intermediate shaft and axles. I'm using a 88-91 CRX Si throttle cable and clutch cable.
You can use the Integra throttle cable and clutch cable as well. Also you can use 94-01 Integra axles as long as you use a matching int. shaft. You will then have to replace the driver's side tranny seal to a 94-01 Integra also.
EF_ST@TUS
Oct 14, 2008 10:12 PM
zenon8890
Feb 27, 2007 02:32 PM
g2tegsown
Aug 26, 2005 01:29 PM
See Are X
May 7, 2002 07:05 PM
speedjunkeez
Aug 15, 2001 10:18 PM
