h22 hatch suspension-spring rate question??
i'm going to be building a h22 hatch next month
what spring rate is recommended....
I'm leaning towards coilovers with a 500/400 front/rear rate
think this is good, or should i go stiffer or softer?
I'm not to worried about a rough ride, just want it to handle half decent.
mostly it will be a street car, with some light/occasional drag/road course racing.
ideas...opinions???
ideas...opinions???
Re: h22 hatch suspension-spring rate question?? (AMS MIKE)
yeah.. what u have in mind should work great, especially in a hatch. if they are actual springs it'll be alot stiffer ride than stock, but it will be somewhat smooth too...
if they are them shorty coilovers.. it'll be pretty bouncy.
Re: h22 hatch suspension-spring rate question?? (hondaZvic)
For street my car handles well and I have my CX spring with JDM springs. FOr racing applications, Ground Control makes coilovers with "hh2a spring rates. Give them a hollar, it goes for 300 dollars.
Re: h22 hatch suspension-spring rate question?? (jmayhew)
It's going to handle like a brick. Mine did. You need good struts and most struts can only handle up to 400lb spirings.. unless you spend over $1K on em. Progress makes a package for H22 hatches that is really good. The key is a big fat rear sway bar to help dial out some of that understeer. Check out http://www.beaksproducts.com for their kit if you don't like progress.
Good luck.
Good luck.
Re: h22 hatch suspension-spring rate question?? (sol-racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol-racer »</TD></TR><TR><TD CLASS="quote">http://www.beaksproducts.com</TD></TR></TABLE>
that stuff looks really nice.
