H22-EG more Knock sensor fun
I have the CEL -23 and I just want some other's feedback on this.
I do not have shielded wire, but from reading all the posts, I will do this soon.
I have a 2 wire knock sensor. What are these from? I grounded the GRN wire from it to sensor ground and the other to D3.
MY QUESTION IS... When does the CEL usually come on for people with KS problems? I drive mine for 5-10 minutes and it usually comes on after the engine is warmed up. Would this indicate what the problem is? I"m going to shield the wire and then if I still get a code, I'm going to get a 1 wire KS.
Re: H22-EG more Knock sensor fun (SleeprCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeprCivic »</TD></TR><TR><TD CLASS="quote">MY QUESTION IS... When does the CEL usually come on for people with KS problems? I drive mine for 5-10 minutes and it usually comes on after the engine is warmed up. Would this indicate what the problem is? I"m going to shield the wire and then if I still get a code, I'm going to get a 1 wire KS.</TD></TR></TABLE>
No, the KS code does not come on until you drive it for a bit. You problaby have:
1) bad wiring (sheilded that wire, y0)
2) bad sensor
2) bad sensor
italian_virus
10-13-2010 08:28 AM
JBirch_97Prelude
05-27-2007 01:03 PM
