civic h22 ecu problem
k i have a 97 civic with an h22 and throwing check engine code 24 and it has no power tell vtec hits and it back fires. i just got the engine complete change over from hmotorsonline what did thng is my problem. do you think it could be my obd2 to obd1 converter.
i think it is a hasport wiring converter and i had ProSpeedPower do the engine harness wiring. Should I try a new ecu. Is it a p13 ECU?
Modified by HONDAofPOKY at 11:24 PM 6/30/2004
Re: civic h22 ecu problem (integr8er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integr8er »</TD></TR><TR><TD CLASS="quote">make sure ur dizzy isnt wired 180 degrees out</TD></TR></TABLE>
i did that when i first got my car going... didnt realize what had happend... and then we tuned it best we could.. months and months later.. figured it out, corrected it. and have been trying to tune ever since... eh...
Re: (HONDAofPOKY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDAofPOKY »</TD></TR><TR><TD CLASS="quote">my dizzy 180 degrees out what is that. sorry but i dont know what you are talking about</TD></TR></TABLE>
distributor. If its wired 180 degrees out it will still run, (like crap).
Re: civic h22 ecu problem (HONDAofPOKY)
If you are not knowledgeable enough to fix this problem yourself, take it back in to whomever installed it and tell them it is not performing the way it should and that they need to fix it.
