Need help with axle problems!!!
Old Jun 14, 2004 | 02:44 PM
crx8psi's Avatar
Default Need help with axle problems!!!
Alright well first of all I have a 94 cx hatch with a b16a2 swap and gsr tranny, well my problem is my axle went bad so i replaced it and not even a hour later the outboard cv joint gives out and leaves me stranded so I take the pos autozone axle back and then decided to buy their performance axle so I did that and put it in and then about a week later same thing happens again leaving me stuck once again. What could be causing this to happen??? It is really ticking me off.
Any help is appreciated, Thanks.
BTW I am using a 94+ integra axle and this is happening on the drivers side...
Old Jun 14, 2004 | 08:34 PM
crx8psi's Avatar
Default Re: Need help with axle problems!!! (crx8psi)
Anyone???
Old Jun 14, 2004 | 11:16 PM
david90's Avatar
oh boy. I just did autozone axle swap and I hope I don't end up with a bad axle like yours.
Are you boosted? Autozone axle is not for boosted application.
Old Jun 15, 2004 | 12:55 AM
hondaZvic's Avatar
Default Re: Need help with axle problems!!! (david90)
sorry yall.. autozone axles arent worth **** at all....
Old Jun 15, 2004 | 06:14 PM
crx8psi's Avatar
Default Re: Need help with axle problems!!! (hondaZvic)
No I am not boosted at all, And I know theyre not worth **** because I work there, but thats why i got them they were cheap. But now I see where cheap gets ya!!
Old Jun 16, 2004 | 04:39 AM
EKB18BPR3's Avatar
same **** happened to me with NAPA axle...ur better off buyng a used oem from either here or ebay than buying autozone, NAPA, carquest...
hardcore97
Transmission & Drivetrain
Dec 6, 2012 01:11 PM
rhdekhatchie
Mar 16, 2008 10:17 PM
wu tang
14
Dec 17, 2007 09:23 AM
elmo908
May 27, 2007 04:37 PM
14bcoupe
Dec 12, 2004 02:35 PM
