B18c type r swap problem/////////////////////////////////////////////////
Old Oct 30, 2008 | 06:32 PM
ej8fosho's Avatar
Default B18c type r swap problem/////////////////////////////////////////////////
I have a 1997 civic cx, just but a 97 jdm b18c type r into it. i used my old harness and just swapped the pluggs. I wired th iacv, vtec selinoid, and knock sensor, and changed one olther plug on intake manifold. everything else plugged in except a crankshaft sensor but i dont think the b18 has that.
My car turns over but will not start it has air spark and fuel what do you thin it could be? thanks
Old Oct 30, 2008 | 08:01 PM
LA_HONDAS's Avatar
Default Re: B18c type r swap problem///////////////////////////////////////////////// (ej8fosho)
are the plug wires on right?
what ecu your using?
the flat part of dizzy cap is top
should look like this
_________
---3---4---
---1---2--- ---->FR
---\__/---
[_____________O<cam gears
----4--3--2--1----
______________O<^
Modified by LA_HONDAS at 11:16 PM 10/30/2008
Old Oct 30, 2008 | 08:15 PM
LA_HONDAS's Avatar
THE CKF BYPASS TRICK CLICK HERE
Old Oct 30, 2008 | 08:38 PM
ej8fosho's Avatar
Default Re: B18c type r swap problem///////////////////////////////////////////////// (LA_HONDAS)
using the jdm p73 ecu , ill have to check on the distributor tomorrow pretty sure the plugs are right but not positive
Old Oct 30, 2008 | 08:42 PM
LA_HONDAS's Avatar
try this if everything is right^^^^
what engine harness did you use?
Old Oct 30, 2008 | 08:54 PM
ej8fosho's Avatar
i dont need to do the ckf bypass trick if im using that ecu do I?
Old Oct 30, 2008 | 08:55 PM
ej8fosho's Avatar
cx harness
Old Oct 30, 2008 | 09:06 PM
LA_HONDAS's Avatar
if the ecu is obd2 then yes you do
Old Oct 30, 2008 | 09:14 PM
ej8fosho's Avatar
do you need to if its a jdm ecu
and my ecu doesnt have an immobilizer in it right??
Old Oct 30, 2008 | 09:25 PM
LA_HONDAS's Avatar
yes you need it with a jdm ecu
and that shouldn have nothing to with not starting up
just check the plug wires are right and if thats good do the ckf thing and it should start right up
Modified by LA_HONDAS at 12:30 AM 10/31/2008
Old Oct 30, 2008 | 09:29 PM
ej8fosho's Avatar
alright thanks for the advice
Miguel613ekb18c
Jun 9, 2013 08:49 PM
derrickkong888
Aug 28, 2012 06:43 PM
jtracing919
Jan 9, 2005 07:31 AM
thehatchninja
Mar 5, 2003 10:21 AM
