b18c1 oil pumps: can i use one off a 2000 si or does any other gen work? Cant find no one that sells
b18c1 oil pumps: can i use one off a 2000 si or does any other gen work? Cant find no one that sells them new.... look inside.
I have a 94 obd1 gsr with a b18c1 motor i need an oil pump. Since majestic honda and non of the parts stores sells this separate or just dont carry acura parts i cant find one....
Can i use a b16 2000 si civic oil pump? How about the 96 and up integra gsr? Would the crank angle sensor mater since the obd1 and 2 oil pump differences if any? What about the oil squarters in the c1 block is that oil pump gonna have enough oil pressure to keep up?
Any input thanks....
Anyplace that sells this cheap lmk.
Re: b18c1 oil pumps: can i use one off a 2000 si or does any other gen work? Cant find no one that s
So can i use the oil pump as long as it is obd1 ? can i use obd2?
i can use these oil pumps correct?
del sol 94 dual cam vtec (b16)
2000 civic si (b16)
96+ integra gsr (b18)
Does obd 1 or 2 matter? i have obd 1.
2000 civic si (b16)
yes you should be able to use an si or the del sol oil pumps either or. if you do use one from an obd2 vehicle the lower timming cover is different because of the crank angle sensor. if you can run another obd1 pump if not you can mod you timming cover to fit the obd2 style pump.
Is it better to use oem or will any brand pump do? [freak] topline oil pumps.
Ditto
Re: (80 dolla crx hf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80 dolla crx hf »</TD></TR><TR><TD CLASS="quote">Is it better to use oem or will any brand pump do? [freak] topline oil pumps.</TD></TR></TABLE>
99% of the time its better to use OEM parts.
Re: (RotiEatter)
Yeah i know 100% true....
What about using the 94 delsol (b16) vtec oil pump of the b16 motor?
I cant find no one that carrys just the 94-95 gsr oil pump the dealer wants 300 for it and no one else can get it or carry it
Re: (boostedcivicsir)
What about the obd 1 delsol dual cam vtec with the b16 motor? its obd1
If i use obd 2 i have to change timming covers or trim one i am not about to hack a good timming cover
Re: (Launchpad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Launchpad »</TD></TR><TR><TD CLASS="quote">Better change your name to 220 dolla crx hf now </TD></TR></TABLE>
WOW HILARIOUS MY FRIND....AHAHAHA
Nah no need to change the name the crx i bought for 50 i sold to some one else already
i got a 94 integra gsr now i just need a dam oil pump
you can use a OBD2 pump on the OBD1 engine but like mentioed before the lower timing belt cover will not fit. you have to change the lower timing belt cover to a OBD2 style.
the top line pumps are fine. but for the extra 20-30 bucks you are better off getting a new OEM one.
turbosol_16
02-01-2007 08:48 AM
