vtec not activate
Old Sep 25, 2008 | 09:41 AM
crx-b18c's Avatar
Default vtec not activate
I install h22 in my brother ef and the vtec dont want engage.I made obdo to obd1 convertion and vtec wire harness and i use accord obd1 dizzy guts inside of h22 shell any can help me.Iam running chipped p28
Old Sep 25, 2008 | 10:17 AM
IntegraType-R's Avatar
Default Re: vtec not activate (crx-b18c)
cels?
is the vtec noid grounded?
Old Sep 25, 2008 | 11:20 AM
crx-b18c's Avatar
Default Re: vtec not activate (IntegraType-R)
sorry what means cels?
Old Sep 25, 2008 | 11:24 AM
FST GSR 1's Avatar
Check Engine Light = CEL
Old Sep 25, 2008 | 11:40 AM
crx-b18c's Avatar
Default Re: (FST GSR 1)
thanks but no check engine light on
Old Sep 25, 2008 | 11:46 AM
Default Re: (crx-b18c)
Check your Ground wire coming from the vtec noid.. if it is infact grounded..
I'd check your oil.
Take the noid off and clean the screen possiblely..
make sure your chipped ecu has vtec engaged.
Old Sep 25, 2008 | 07:40 PM
ten2doyle102's Avatar
will it throw a cel if it not grounded properly????
Old Sep 26, 2008 | 09:15 AM
turboH22Aakkord's Avatar
Default Re: (ten2doyle102)
is the tach and Speedomiter working? if not, check you vss (speed sensor).
efkilla
Jun 27, 2013 06:02 PM
90 ef
34
Oct 29, 2009 04:41 AM
folta2169
Apr 29, 2005 11:06 PM
SLOAZZ95
Aug 13, 2004 08:31 AM
Yellb16crxsi
Feb 13, 2003 01:57 PM
