h2b timing
Old Sep 18, 2008 | 10:28 PM
alaskanlue's Avatar
Default h2b timing
I was wondering if the balance shaft timing would affect the timing?
Seems like I cant set my timing to 16* without advancing my dizzy all the way advance. I think I rotated the crank with the balance shaft belt off when I was doing a manual tensioner conversion, wasnt sure if it would affect timing.
If it does could I just take off the balance shaft belt to reslove the problem?
And for the h2b evo flywheel, there seems to be 5 marking? Im guessing first one is 0, second is 14,15,16 and Im not sure about the last one.
--0
-15
Searched, but couldnt find much. Let me know, Thanks.
Old Sep 19, 2008 | 05:14 AM
2fastGSR's Avatar
King of the One Liners
Default Re: h2b timing (alaskanlue)
balance shafts have nothing to do with timing.
use the 15 mark on flywheel
Old Sep 19, 2008 | 01:06 PM
alaskanlue's Avatar
yea, I tried the 15 mark but the camgear doesnt line up. Only line up with 0 and 16. Its kinda werid
Old Sep 19, 2008 | 01:55 PM
LA_HONDAS's Avatar
Default Re: (alaskanlue)
that should work then if it line up
turn it over 2 time then turn it over one more time to TDC and if everything lines up your good to go
Old Sep 19, 2008 | 05:11 PM
alaskanlue's Avatar
so if the everything line up and the dizzy needs to be advance all the way for it to be at 16*, it should be fine? Let me know, not really good at this stuff. Thanks
Old Sep 21, 2008 | 05:38 AM
2point2's Avatar
On a cut valve cover you can point the timing gun at the cam gears.
Old Sep 21, 2008 | 10:41 AM
alaskanlue's Avatar
Default Re: (2point2)
didnt know that, thanks.
BPoppert
Aug 12, 2015 06:52 AM
98bucket
Nov 21, 2010 03:57 PM
chue_li
Jul 4, 2006 12:58 PM
