Easiest swaps
Old Aug 29, 2008 | 11:17 AM
corkss's Avatar
Default Easiest swaps
I'm picking up a 99 civic ex with a blown d16y8 for $1000!!!
Whats the easiest swap in this car, or what motor do I want to shoot for?
I've done a lot of research but want a straight forward answer to this particular model!
Thanks in advance
Matt
Old Aug 29, 2008 | 12:03 PM
oneslowstd's Avatar
Default Re: Easiest swaps (corkss)
Well a direct swap would be a mini me! Or a JDM D15B which i personally like the best out of all the sohc's! But if you have the money just slap a used B18b and save cash and do an LS/vtec the swap is very straight forward, no cutting or special parts are needed just axles mounts and shift linkage
Old Aug 29, 2008 | 12:19 PM
twinksack's Avatar
* B A N N E D *
Default Re: Easiest swaps (oneslowstd)
there all easy if you know what your doing
Old Aug 29, 2008 | 01:22 PM
corkss's Avatar
if i get a motor that is obd2, do you even have to switch harness?
Old Aug 29, 2008 | 01:29 PM
oneslowstd's Avatar
Default Re: (corkss)
no everything is plug and play! you could even use a obd 1 engine or obd0 and convert your whole car to obd 1
Old Aug 29, 2008 | 02:41 PM
LA_HONDAS's Avatar
Default Re: (oneslowstd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowstd &raquo;</TD></TR><TR><TD CLASS="quote">no everything is plug and play! you could even use a obd 1 engine or obd0 and convert your whole car to obd 1</TD></TR></TABLE>
not true at all
96-98 and 99-01 motor harness are diff...
OP just reuse your motor harness and call it a day
and if you use a obd0-1 motor just rewire iat sensor
Old Aug 29, 2008 | 03:37 PM
oneslowstd's Avatar
Default Re: (LA_HONDAS)
what i meant was he can use his harness with any year b series motor, and if he didnt want to deal with bs obd2 **** he could just convert to obd1
Old Aug 30, 2008 | 01:14 AM
corkss's Avatar
may sound stupid, but would it be easier keeping it obd2? Rather than converting to obd1
Old Aug 30, 2008 | 09:12 AM
oneslowstd's Avatar
Well in my eyes its ten times better that obd2, and its super easy to do, also if you are looking to get tuned some day you will find that its much harder to tune a obd2 vehicle and 8/10 times a tuner wont even touch a obd2 car. So if I were you just get a obd1 motor with the distributer already intact buy a chipped or even try to find a virgin p28, go to rywire.com and buy the obd2 to obd1 jumper harness!
Old Aug 30, 2008 | 11:26 AM
corkss's Avatar
Alright thanks everyone, I think I got my questions answered
Thanks a lot !
DualCam_V
24
Aug 27, 2010 02:37 PM
jaydeemej8
Sep 25, 2007 04:07 PM
zcivicz
May 29, 2004 10:10 AM
boosted-delslow
Feb 27, 2004 01:40 PM
brockscivic
Nov 19, 2003 05:43 PM
