obd1 swap into an ek too complicated, swap out harness for obd1?? INSIDE AND OUT!
ok so ive been asking around about swapping an obd1 engine into my ek. i read over the sticky above, and it was great... and complicated... so my friend suggested i swap out my harness for an obd1 harness, cant do it right? well what if i swap out my interior harness for an obd1 harness also?!?! will that work?? is it possible at all? tell me what you think.
Re: obd1 swap into an ek too complicated, swap out harness for obd1?? INSIDE AND OUT! (Romo Pyro)
just use your stock ENGINE harness and just add the vtec vtec pressure knock wires
<FONT SIZE="4"><FONT COLOR="red">WHEN DOING MOTOR SWAPS JUST USE THE ENGINE HARNESS FOR THAT CAR AND MOD IT TO FIT THE ENGINE YOUR USING IT'S THAT EASY</FONT></FONT>
Modified by LA_HONDAS at 6:01 PM 10/30/2008
Seagull Management
Theoretically possible, but not worth doing. Its far, far easier to swap components to OBD2.
Re: obd1 swap into an ek too complicated, swap out harness for obd1?? INSIDE AND OUT! (lsvx92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS »</TD></TR><TR><TD CLASS="quote">just use your stock ENGINE harness and just add the vtec vtec pressure knock wires
Modified by LA_HONDAS at 6:01 PM 10/30/2008</TD></TR></TABLE>
Re: obd1 swap into an ek too complicated, swap out harness for obd1?? INSIDE AND OUT! (LA_HONDAS)
Mr. Badwrench
<FONT COLOR="red">WHEN DOING MOTOR SWAPS JUST USE THE ENGINE HARNESS FOR THAT CAR AND MOD IT TO FIT THE ENGINE YOUR USING IT'S THAT EASY</FONT></TD></TR></TABLE>
amen
amen
egvtec
08-18-2008 08:20 PM
ballerchild
12
04-03-2007 12:41 PM
FritzInTN
07-10-2004 09:45 AM
