B18a1 into EJ question
Old Sep 29, 2008 | 05:41 PM
GYChris's Avatar
Default B18a1 into EJ question
Let me first start off by telling you what i have:
2000 DX civic coupe
d15b7 (dont ask)
obdII->obdI jumper harness to a p05 ecu.
Apparently the previous owner had some "bad *** 500whp b-series" motor in it, took it out and threw the single slammer into it to get rid of the car... And now its in my hands. Well the motor taps, smokes, idles rough but i got a hell of a deal on the car and had plans to swap.
I just got my hands on a b18a1 longblock for 100 bones. Now i have some questions.
-Is it even worth swapping such an old motor into a 2000 coupe?(supposedly has low mileage, saw the tach on the car it came out of- 120,xxx)
-What should I do electrical wise? Keep the jumper harness and stay with an obd1 ecu?
And....Since the motor is obd0 should i get an obd2 b18 intake mani?
-CV axles- The guy gave me 2 DA ls cv axles and half shaft, will these work for my application?
-Am i just being a dumb *** and need to search harder?(have searched quite a bit)
If this turns out to be more of a pain in the *** then expected, i can easily flip the motor and get my money back + some
Help would be greatly appreciated
Modified by GYChris at 6:52 PM 9/29/2008
Old Oct 1, 2008 | 07:40 PM
ltrkstr2k's Avatar
Default Re: B18a1 into EJ question (GYChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GYChris &raquo;</TD></TR><TR><TD CLASS="quote">-Am i just being a dumb *** and need to search harder?(have searched quite a bit)
Modified by GYChris at 6:52 PM 9/29/2008</TD></TR></TABLE>
yes
Old Oct 6, 2008 | 01:47 PM
MR.johnson's Avatar
Default Re: B18a1 into EJ question (ltrkstr2k)
for a first timer, just buy a complete swap and dont fart around.
Old Oct 6, 2008 | 04:15 PM
GYChris's Avatar
Default Re: B18a1 into EJ question (MR.johnson)
not a first timer and cant exactly pull the money out of my *** to do the whole swap
all i need is tranny, shift linkage and figure out what im doing with the harness
MyVtecLouder
Sep 15, 2010 02:05 PM
GYChris
Oct 1, 2008 03:18 PM
93civciv
Apr 1, 2005 09:00 PM
