Whats up with my axles?
The passeger side one doesnt look like its all the way in and the driver side the cv cover acts like it has suction holding it down. Its right where i had to grind the block for it to clear. Can i stab it with a pin hole to let air in and form it back to normal or is there something else to do?
Re: Whats up with my axles? (turboedsupe)
that looks right to me
what kind of car its in you could have the wrong axle
what ever you do dont put a hole in it or you will be buying a new in 6 months and cleaning your bay
Re: Whats up with my axles? (LA_HONDAS)
its a h2b into my civic and im using integra gsr axles. The bot looked fine then when i put it on thats when the air sucked the boot in now i cant get it to get back to original formation
did you pull on axle if so that why it did that just push axle in and work the boot with your hand or cut the small strap off so you can get air in it then put a zip tie on it
I worked a small flat head in right there at the clamp and it worked. And yes the evo kit and it was overall a good install
pm 2fastGSR he had the same kit
but i know the evo kit sits a 1/2" to the pas...side so thats one thing with that axle but it should be to go
